EI-Nis RIP galerija
EI-Nis RIP galerija
PostPostao/la deki64 » Uto ožu 17, 2015 9:23 pm
Za sve ljubitelje cijevi,slike iz fabrike EI-Nis radio cijevi,slikao sam 2010te,fabrika je prestala sa radom
u lipnju 2007 ,"neuspesno" privatizovana,deo masina kupio Western electric,pogledajte naljepnicu na prvoj slici.
Ostale masine prodate u staro zeljezo prosle godine ,ovo su slike iz finalne proizvodnje i testiranja.
Slike iz ostalih delova proizvodnje,pogon sklapanja,motanja resetki,neki drugi put.
Vise nicega nema sa ovih slika ,mozda nekog interesuju ove slike ,pa izvolite.
deki64
Postovi: 44
Pridružen: Ned ožu 15, 2015 10:15 pm
Re: EI-Nis RIP galerija
PostPostao/la Master of disaster » Uto ožu 17, 2015 9:26 pm
Propast gdje god se okreneš :(
PostPostao/la deki64 » Uto ožu 17, 2015 9:28 pm
Jos par slika
deki64
Postovi: 44
PostPostao/la deki64 » Uto ožu 17, 2015 9:37 pm
A sve je pocelo 1950te,zgradu fabrike RR ,radio rentgen,prvobitno ime EI-Nis ,sagradili su Nemci ratni zarobljenici.
Prvi inzenejeri su bili iz Nemacke,na slici je ploca koja svedoci o osnivanju.
Tekst ispod je pocetak izvjestaja americkog vojnog strucnjaka koji je na zahtev vlasti posettio fabriku 1952ge i
podneo izvestaj ,te predlozio sta i kako kupiti od opreme :
The factory, R. R. Savodi, located at Nis, Serbia, has been
established to manufacture receiving tubes, X-Hay tubes and Y-Ray
apparatus. At present the receiving tube production facilities are
located in a single story building having an area of 1,200 square meters.
A considerably larger factory area, providing a manufacturing space of
approximately 19,800 square meters has been constructed and is being
equipped for future production. In this space, approximately 11,000
square meters is planned for receiving tube production; 1,600 square
meters for X-Ray tube production and 7,200 square meters for X-Ray
apparatus production. This building has three floors, The space
occupied by the present tube plant of 1,200 square meters will be used
as a stock roam after the product equipment has been moverd into the larger
area, Separate small buildings will house gas production facilities and
other auxiliary services. The factory has good access to a railroad and
a highway, Approximately 600 workers of all categories are employed at
present at the R. R. Savodi factory, but the ma)ority of them are engaged
in building and installing equipment for the above areas.
deki64
Postovi: 44
PostPostao/la deki64 » Uto ožu 17, 2015 9:42 pm
Nastavak izvestaja je zanimljiv,opisuje planove proizvodnje ,osim civilnih evropskih tipova cevi na pocetku spiska
slede americke cevi,tj tipovi koji su se trebali proizvoditi za americke radio uredjaje koje je YU pocela dobijati ranih
pedesetih,9002 masovno u avionskim radijima recimo,baterijske cijeci za an/grc9 itd.
Ti planovi za americke tipove se nisu ostvarili,osim za malu pilot seriju,ja naime imam cijev RR zavodi 6Q7 GT
sa bijelom petokrakom i znakom RR zavodi Nis.
A. Present Production and Plans
At present 300 to 400 rectifier tubes of the AZ1I type (a
European full-wave rectifier with a side contact base) are being pro-
duced daily. Pilot production is also under way for the 6K7G (an
American pre-war pentode), the EZ12 and FZ21 (European rectifiers) and
the EBL21 (an European double diode -- -- output pentode). Present plans
are that the following types will be introduced into greater production
later this year: 6K7G (Sept.), EZ12 (Sept.), KZ21 (Sept.), EBL21 (Oct,)
and ECH21 (Nov.).
It is estimated that the following quantities of receiving
tubes will be produced for civilian consumption on an annual basis by
1954:
EBL21 -- 100,000; ECH21 -- 200,000; rectifiers (AZ1, AZ11, EZ12
and EZ21) -- l50,000; and all other types -- 50,000.
On August 19, 1952, at a meeting in the Yugoslavian Foreign
Office in Belgrade, the requirements for receiving tube production to
meet, military needs for one year were stated as follows:
Battery Operated Filament Types
Quantity
lA3 20,000
lL4 140,000
1T4 120,000
lR5 80,000
1S5 80,000
3A4 100,000
3Q4 20,000
Indirectly Heated Cathode Types
Quantity
9002 70,000
9003 10O,OOO
6BA6 20,000
6BE6 6,000
6AL5 10,000
6AK5 10,000
12AU7 5,000
6C4 16,000
It was estimated by the staff of R. R. Savodi that a total of
20,000 to 30,000 tubes of the first five types would be required on an
annual. basis for civilian use. It is also estimated that the above
annual requirement for military support will increase after the first
year to approximately twice this quantity within two or three years,
bringing the total annual requirement for miniature tubes to about
1,500,000 per year.
At a meeting on August 26, 1952, it was decided to consider
the initial requirements for miniature tubes to be in the order of
1,000,000 units and to plan accordingly. Further detail on the plans
for this phase of production are given in the section, "The Future
Production Program",
deki64
Postovi: 44
PostPostao/la pamook » Uto ožu 17, 2015 10:25 pm
u yebenti.... ove fotke paraju srce :(
kad vidim sve one "satove", uhhhhhh :P ... poslagao bi ih po zidu ko palisadu i pravio se da sam Jack Lemmon, sa ili bez Jane Fonda :lol: ...
yebenti :cry:
PostPostao/la deki64 » Uto ožu 17, 2015 10:36 pm
Ih a tek sta je bilo po magacinima rezervnih dijelova ijaooo..
Vazno je da su fabriku sjebali tek onako,a mogla je raditi.
Radila je cak i za vrijeme sankcija i bombardovanja .
Izvozili su i pod sankcijama ali demonkratske promene
nije mogla preziveti.Znam da je pocetna izvozna cijena
za jednu KT90 bila 14$ tamo 1989te ,prva isporuka u USA
10000 komada puta 14$ ,i sve to stane u jedan kombi
a znacajan novac ,ali...
Inace sva oprema je bila Philips i to je prakticno bila
najmladja Philips oprema u svetu koja je ostala do skora.
Zato je Western electric i kupio masine koje su mu trebale.
Ali to je bio tek cetvrti deo ,tri cetvrtine su prakticno
bacene .
deki64
Postovi: 44
PostPostao/la audio kutak » Uto ožu 17, 2015 11:02 pm
a što reći nego... žalosno....
kod mene u Velikoj Gorici, prema Kupi, su u jednom vojnom skladištu spalili brda i brda lampi i vojne opreme....
dana je naredba samo tako, da se nije ni gledalo što se ima.... ljudska glupost nema granica..
PostPostao/la audio kutak » Uto ožu 17, 2015 11:03 pm
naročito su mi lijepi oni okrugli voltmetri i ampermetri...
PostPostao/la deki64 » Uto ožu 17, 2015 11:11 pm
e pa spalili su zive novce nazalost,inace neki okrugli instrumenti su velicne singlice pa cak i LP ploce
deki64
Postovi: 44
DrFireBottle pregledava forum i 2 gostiju
