Lateral CFA 120W i 80W
Re: Lateral CFA 120W i 80W
PostPostao/la Bepone » Ned sij 31, 2021 1:19 pm
tom_hifi napisao:. Najviše su me, zasada, impresionirali visoki tonovi. Toliko su kristalno jasni, precizni, a s druge strane imaš osjećaj da su povučeni, a nisu nimalo. ;)
jooj kad cujem to "kristalno" iz zvucnika , gasim na mjesec dana ...i uhvatim se gitarskih pojacala :lol: :lol:
Postovi: 6122
PostPostao/la tom_hifi » Ned sij 31, 2021 3:02 pm
Bepone napisao:
Imam SE pojacalo doma, znaj da sam i ja osjetljiv na visoke. Odlično radi, ne tako kako si ti shvatio.
PostPostao/la tom_hifi » Uto tra 19, 2022 11:36 am
dadod napisao:Pa ta alu plocica je spojena na masu hladnjaka tj. uzemjena i bas ona sprecava (uz vece gate otpornike) osciliranje.
Tom je predlozio da dam nove gerbere pa se ovim vracamo jedan korak u natrag jer su ponovo u igri VAS kondenzatori dodani paralelno emitter otporniku.
120W-OITPC-LMOS-TO-3P-gerbers1_1.zip
120W CFA lateral mosfet simple though hole 1.1b
all resistor metal film 0.6W 1% if not stated differently
power supply +-50V up to +-55V
C1 1uF polypropylene
C2 470pF C0G 5%
C3 100uF 35V
C4 100uF 35V
C5 220pF MICA 5% or C0G
C6 47pF MICA 5% or C0G
C7 220pF MICA 5% or C0G
C8 33n to 330n polypropylene
C9 22pF MICA 5% or C0G
C10 22pF MICA 5% or C0G
C11 33n to 330n polypropylene
C12 220uF 63V
C13 220uF 63V
C14 100nF polypro
C15 22uF 25V
C16 220uF 63V
C17 220uF 63V
C18 220uF 63V
C19 220uF 63V
C20 100nF polypropylene
C21 1uF polypropylene
C22 10uF 25V
C23 10uF 25V
C24 100nF
C25 1uF polypropylene
C26 330pF
C27 330pF
D1 12V zener
D2 1N4148
D3 1N4148
D4 12V zener
D5 3A 200V
D6 3A 200V
D7 1N4148
D8 1N4148
D9 15V zener
D10 15V zener
L1 0.5uH
M1 ECX10N20 or ECX10N20-S better matching
M2 ECX10N20 or ECX10N20-S "
M3 ECX10P20 or ECX10P20-S "
M4 ECX10P20 or ECX10P20-S "
P1 1k multiturn
Q1 BC560C
Q2 BC550C
Q3 BC550C
Q4 BC560C
Q5 2N5551
Q6 2N5401
Q7 KSA992F
Q8 KSC1845F
Q9 KSC3503 or MJE340 or MJE243 (for +-50V)
Q10 KSA1381 or MJE350 or MJE253 (for +-50V)
Q11 BC550
R0 10R
R1 220R
R2 75k
R3 10R
R4 10R
R5 5k6
R6 5k6
R7 6R8
R8 6R8
R9 5k6
R10 5k6
R11 10k
R12 10k
R13 2k7 2W metal oxide 5%
R14 680R
R15 5R6
R16 5R6
R17 22R 1W 1% metal film
R18 680R
R19 2k7 2W metal oxide 5%
R20 1k5 can be lowered down to 220R
R21 220R
R22 220R
R23 91R
R24 2k2
R25 330R
R26 91R
R27 33R
R28 22R
R29 22R
R30 33R
R31 100R
R32 680R
R33 680R
R34 560R
R35 560R
R36 0.27R (0.22R) 4W wirewound
R37 0.27R (0.22R) 4W wirewound
R38 0.27R (0.22R) 4W wirewound
R39 0.27R (0.22R) 4W wirewound
R40 6R8 2W metalfilm
R41 2R2 2W metalfilm
R42 10k
R43 1M
R44 1M
R45 560R 8W (four 560R 2W metalfilm 1%)
U1 LF411
Damire, u BOM-u se potkrala mala greškica ...
R5, R6, R9 i R10 imaš 5K6, a na shemi je R5 i R10 10K i R6 i R9 1K. Koliko se sjećam i gledajući prošle sheme, ovo je točno, jelda?
Uz to, sjećam se v1.2 gdi je umjesto R5 i R10 brika, a R6 i R11 su 11K. Što od, svega toga, preporučaš? :)
PostPostao/la dadod » Uto tra 19, 2022 10:11 pm
Eh, to je bilo tako davno, moram malo pogledati.
dadod
Postovi: 888
PostPostao/la dadod » Sri tra 20, 2022 12:09 pm
tom_hifi napisao:
C2 470pF C0G 5%
C3 100uF 35V
C4 100uF 35V
C12 220uF 63V
C13 220uF 63V
C14 100nF polypro
C15 22uF 25V
C16 220uF 63V
C17 220uF 63V
C18 220uF 63V
C19 220uF 63V
C22 10uF 25V
C23 10uF 25V
C24 100nF
C26 330pF
C27 330pF
D1 12V zener
D2 1N4148
D3 1N4148
D4 12V zener
D5 3A 200V
D6 3A 200V
D7 1N4148
D8 1N4148
D9 15V zener
D10 15V zener
L1 0.5uH
P1 1k multiturn
Q1 BC560C
Q2 BC550C
Q3 BC550C
Q4 BC560C
Q5 2N5551
Q6 2N5401
Q7 KSA992F
Q8 KSC1845F
Q11 BC550
R0 10R
R1 220R
R2 75k
R3 10R
R4 10R
R5 5k6
R6 5k6
R7 6R8
R8 6R8
R9 5k6
R10 5k6
R11 10k
R12 10k
R14 680R
R15 5R6
R16 5R6
R18 680R
R21 220R
R22 220R
R23 91R
R24 2k2
R25 330R
R26 91R
R27 33R
R28 22R
R29 22R
R30 33R
R31 100R
R32 680R
R33 680R
R34 560R
R35 560R
R42 10k
R43 1M
R44 1M
U1 LF411
Korektna je sema, znaci R5 i R10 treba biti 10k a R6 i R9 1k. ne trebaju brike. ;)
dadod
Postovi: 888
PostPostao/la tom_hifi » Pet svi 13, 2022 11:28 am
Još jedan Lateral CFA je završen. Rađen je jednom mojem prijatelju koji živi u Zagrebu, nije forumaš. Kada je čuo kako radi 'moj CFA', htio je identičnu kopiju, manje više. Dadod je bio sretan što će zaživjeti još jedan CFA s lateralcima, a mislim da, tko može, neka se slobodno upusti u izgradnju. Ja osobno se ne sjećam kada sam čuo tako dobro zvučeće 'solid state' pojačalo.
Pojačalo na 8R teretu daje 30.7VAC (točno prije rezanja signala, tako je i slikano na slici iznad), što je vrlo dobro specificiranih 117.8W Pout. Napon napajanja je bio +-52V, a kako kod mene u večernjim satima poraste malo napon, mislim da bi se preskočilo deklariranih 120W po kanalu.
Koliko znam, Damir ima CFA 200W popunjene pločice, ja imam jedan set lateral CFA popunjenih pločica, a i nešto praznih, pa kažem, ako se tko želi upustiti u samogradnju, sa ovim projektom neće pogriješiti.
Hvala Damire na odlično projektiranom pojačalu i što si omogućio nama da ga izgradimo!
PostPostao/la dadod » Pet svi 13, 2022 12:39 pm
Pa jeli prijatelj zadovoljan s ovom izvedbom?
dadod
Postovi: 888
PostPostao/la tom_hifi » Pet svi 13, 2022 2:01 pm
dadod napisao:Pa jeli prijatelj zadovoljan s ovom izvedbom?
Nije još pokupio kod mene, vjerojatno će danas.
PostPostao/la grunf » Pet svi 13, 2022 8:33 pm
tom_hifi napisao:Još jedan Lateral CFA je završen. Rađen je jednom mojem prijatelju koji živi u Zagrebu, nije forumaš. Kada je čuo kako radi 'moj CFA', htio je identičnu kopiju, manje više. Dadod je bio sretan što će zaživjeti još jedan CFA s lateralcima, a mislim da, tko može, neka se slobodno upusti u izgradnju. Ja osobno se ne sjećam kada sam čuo tako dobro zvučeće 'solid state' pojačalo.
svaka čast Tome na uradku :clap:
eto da još nekome lemilica gori :D
e sad ja ne bi bia ja kad ne bi bacia koji upljuvak :lol:
da li si uspoređiva lateral cfa sa A klasom SS-a (alephima,jlh ,i sl) ?
mene golica ovo pojačalo ali mi je previše snage i djelova samo za poslušati kako svira , lateralaca imam gomilu(šta sam uzeo od tebe i orginalnih hitachijevih ) čak i orginalnih 2SK216/J79 ali ja sa laterlacima nikad nisam dobio taj 'čaroban' zvuk koji prati njihovu reputaciju osim kad sam ih direktno pogonio lampom , možda je to problem kad se navikneš na SS A-klasu ali koliko znam nisam jedini :D
Zadnja izmjena: grunf; Pet svi 13, 2022 10:56 pm; ukupno mijenjano 1 put/a.
Postovi: 3046
PostPostao/la grunf » Pet svi 13, 2022 9:56 pm
grunf napisao:ali ja sa laterlacima nikad nisam dobio taj 'čaroban' zvuk koji prati njihovu reputaciju osim kad sam ih direktno pogonio lampom
da nadodam na ovo da sam nakon ovog pokusa umirovia Aleph 3 jer je sviralo puno bolje :D
Postovi: 3046
