Stereo pojačalo (preporuka)
Re: Stereo pojačalo (preporuka)
PostPostao/la Dorian » Sub stu 07, 2020 1:19 pm
aparatusonitus napisao:
Dorian napisao:...tako da po svemu sudeci su to ipak najbolji lateralci ikad proizvedeni...
Lateralci...think again!?
izgleda da si u pravu, eto ne treba vjerovati ni svemu sa velikog diyaudia, def nisam isao u dubinu i na zalost ni nemam ni jedan primjerak toga za stvarni test, zanimljivo da nitko nije to vidio ni prigovorio na 6 stranica koliko je tema isla, isprika svekolikom pucanstvu
https://www.diyaudio.com/forums/solid-s ... -urls.html
Dorian
Postovi: 210
PostPostao/la grunf » Ned stu 08, 2020 10:23 am
Dorian napisao:
https://www.diyaudio.com/forums/solid-s ... -urls.html" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank
je, pokojni AndrewT na trećoj stranici; As far as I know Toshiba don't make or sell any Lateral Power mosFETs. , ali ga niko nije ferma
evo s jednog drugog foruma za svekoliko pučanstvo
The other main category are vertical mosfets - here we can include Toshiba's popular ones and IRF's.
Even if Toshiba called them "Π-MOS" (pi-mos), they belong to the vertical category by their characteristics.
Here we have 3 generations, let's say - first generation (1983 Toshiba databook) were the ones used by Sansui, 2SK405 / 2SJ115. These ones are the closest ones to the lateral mosfets - meaning lower gate capacitance Cgs and lower transconductance Yfs (still about 2x of laterals for about the same gate capacitance, which is a plus).
The second "generation" were 2SK1529 / 2SJ200, used mostly by Sony amps (TA-F707ES for example) and some Kenwood's, from what I saw so far. These have greater transconductance, but also greater capacitance Cgs. Vgs is almost the same as 2SK405 / 2SJ115. A bit more rugged, 10A drain current compared with 8A for Sansui's ones. From their characteristics, let's say that they are "more vertical" than the ones used by Sansui.
And the last generation were 2SK1530 / 2SJ201, used by example in Sony's like TA-FA3ES, 5ES, 7ES and the more popular TA-FA777ES. Also the most rugged ones from the them, with 12A drain current. Again bigger gate capacitance and bigger transconductance.
There were also other ones similar more or less with 2SK1529 and 2SJ200, like 2SK413 / 2SJ118 (most probably "unknown", don't remember seeing them used in amps).
And we have another sort of "even more vertical" like 2SK3497 / 2SJ618, which were used by Denon in some of their amps. These were also made by Toshiba.
The Toshiba ones were "made for audio", meaning that they are "more complementary" than IRF's for example. So this should translate into lower distorsions and better sound. But I think they would need some bigger bias current to sound ok, compared with Hitachi's.
Sound-wise, I can't find anything against them, compared to laterals. If we compare a pair of laterals with a pair of Toshiba's, then there I think are chances that the Toshiba's will have a bit more "slam" in the bass region, due to greater transconductance.
PostPostao/la grunf » Ned stu 08, 2020 10:27 am
bilo bi dobro da odgovorni prebace dio ove rasprave o lateralcima u posebnu temu( npr. lateralci ..) da čoviku ne zakrčimo temu ;)
PostPostao/la norrinraddhr » Ned stu 08, 2020 11:00 am
grunf napisao:norrinraddhr , ne moraš po njuškalu tražiti vintage pojačala ako ti ne bude neke uspomene iz djetinjstva ili nisu klasici ja sam našao bar 20tak pojačala na njuškalu koja nisu stara , ne traže refreš a i kasnije će se opet lako prodati ako se ide na nešto bolje, inače se pojačala ne kupuju na preporuku ili rekla kazala ,već na slušni test pa probaj malo i poslušati nešto da vidiš šta ti paše šta se tiče komentara trgovca iz Sonusarta na Yamahu( nova generacija) generalno bi se složio s njim , međutim ima ljudi kojima paše taj zvuk evo ti par preporuka , ja bi razmislia o unison reserachu , coplandu, primaru ,a posebno o quadu 606 i hafleru, inače ovo su sve pojačala koja su bar za klasu bolja od yamaha, pioneera ,kenwoda i sl. sva ova pojačala su bila kod ljudi koji su ih vjerovatno mazili i pazili tako da bi trebala biti u dobrom stanju, moj prijatelj je za svoje coplande imao ručno sašivene navlake da ne pada prašina kad ne rade, drugi je isto tako napravia za quada :D
https://www.njuskalo.hr/hi-fi-pojacala/unison-research-unico-hybrid-oglas-32506665
https://www.njuskalo.hr/hi-fi-pojacala/rega-brio-3-audiofilsko-integrirano-pojacalo-stanje-10-10-oglas-31672920
https://www.njuskalo.hr/hi-fi-pojacala/copland-csa14-integrirano-hibridno-pojacalo-oglas-32689713
https://www.njuskalo.hr/hi-fi-pojacala/yamaha-ax-1050-oglas-29510884
https://www.njuskalo.hr/hi-fi-pojacala/arcam-a19-oglas-32747460
https://www.njuskalo.hr/hi-fi-pojacala/creek-evo-amp-moguca-zamjena-doplatu-oglas-32009045
https://www.njuskalo.hr/hi-fi-pojacala/rotel-ra-1060-oglas-32668069
https://www.njuskalo.hr/hi-fi-pojacala/primare-i21-amp-cd21-oglas-31969697
https://www.njuskalo.hr/hi-fi-pojacala/pojacalo-audio-analogue-puccini-se-dual-mono-ustroj-oglas-29501731
https://www.njuskalo.hr/hi-fi-pojacala/primare-a-10-oglas-32071217
ima i nekih klasika na prodaju, međutim Hafler je samo izlazni stupanj tako da mu treba pretpojačalo, obavezno provjeriti s prodavačima stanje i poslušati ako se može
https://www.njuskalo.hr/hi-fi-pojacala/musical-fedelity-b1-oglas-29874036
https://www.njuskalo.hr/hi-fi-pojacala/hafler-220-oglas-32765170
https://www.njuskalo.hr/hi-fi-pojacala/quad-izlaz-405-pre-33-tuner-fm3-oglas-32639869
https://www.njuskalo.hr/hi-fi-pojacala/quad-606-66-oglas-32436231
Ne morate, ne smeta mi, osim ako admin vidi potrebu za istim. To je ono što sam tražio, popis nekih brendova na koje bih bacio pogled i da izbacim "ljepotane" iz popisa. Priznajem, ne kužim se u pojačala, poznata su mi ona imena koja sam našao, za ova nikada nisam niti čuo, zato sam i postavio upit da se informiram i odaberem nešto što će mi trajati i biti neki gušt kod slušanja. Lova će ionako otići bilo za ovo ili ono ime.
Hvala grunf na utrošku svog slobodnog vremena oko traženja, ovo je bio konkretan prijedlog koji mi je trebao. Vidjet ću što bih od navedenog mogao realizirati. Ako netko ima još koji brand kojeg bih mogao uzeti u obzir neka slobodno napiše.
Pioneer F-225 Tuner - (1990)
norrinraddhr
Postovi: 189
Lokacija: Virovitica
PostPostao/la Cindra » Ned stu 08, 2020 6:06 pm
Ovo gore su solidna pojačala ali dobar dio ih je od stalnih preprodavača. Vidi s kim se da cjenkati i ja bih radije uzimao od nekog tko prodaje svoje pojačalo a ne ko ih samo vrti za dodatnu zaradu
Cindra
Postovi: 389
