Bias 380mA na tri para Hitachi lateralih mosfet.
Zujanje i grijanje riješeni - temperatura na transformatoru u mirovanju sa 69 na 29 stupnjeva.
Mosfeti +/- 63VDC, driveri +/- 73VDC.
Zamijećen popravak basa.
Pojačalo je dobro sviralo i neispravno.
Interesantno je što je to prvi takav proizvod s kojim se mogla dobiti i dodatna kutijica za "test neutralnosti".
SWDT odnosno Straight Wire Differential Test. Poništavanjem signala na ulazu i izlazu ostaju nam samo poznate i nepoznate rezidualne distorzije.
Ja sam napravio taj sklop i u praksi je to izgledalo tako da sam na zvučnik u drugoj sobi glasno puštao bijeli šum, a na monitoru kraj glave slušao distorziju.
Trimerom na pločici se ta "nula" onda još malo podešava.
U razvoju je sudjelovao "Mr. Fet", Mađar Erno Borbely.
Za kraj dio komentara američkog biznismena Davida Haflera po kojem je brend dobio ime.
Cijeli tekst je na Stereophile-ovim stranicama.
The starting point is that it is very difficult to compare amplifier A with amplifier B to make a quality assessment. The conventional A/B test, or any comparison, may indicate that the amplifiers are different, but how can one determine which is "best"? "Best" is a matter of judgment, and even though many golden-eared experts think their ears are infallible, they disagree among themselves as to amplifier quality. What is needed is an accurate reference against which an amplifier can be judged—a reference which does not involve the entire listening chain, from source to loudspeaker, but which is the equivalent of a perfect amplifier. That reference is the straight wire.
Read more at
http://www.stereophile.com/content/manu ... L0FT165.99" target="_blank
