GainWire mk2
Re: GainWire mk2
PostPostao/la sinisap » Pet pro 05, 2014 8:11 pm
:handgestures-salute: Ja dolazim osobno..
sinisap
Postovi: 353
Re: GainWire mk2
PostPostao/la dadod » Pet pro 05, 2014 11:19 pm
zendra 1 - skupim i platim osobno
pammok 1
yoke 2
LesFaul 1
Schultz 1
sinisap 1 - dolazi osobno
SaWa 1
Edison 1
misho 1 - pokupim osobno i platim
dadod
Postovi: 871
Re: GainWire mk2
PostPostao/la Edison » Pet pro 05, 2014 11:23 pm
Schultz napisao:Meni i Edisonu možeš poslati zajedno pa ćemo se mi već nekako naći....
Moze... saljes meni i Shultzovu, ja placam obje pa cemo se Schultz i ja raskusurat na kahvi... :)
Postovi: 5900
Re: GainWire mk2
PostPostao/la Schultz » Pet pro 05, 2014 11:38 pm
Eto...
Re: GainWire mk2
PostPostao/la dadod » Sub pro 06, 2014 1:19 pm
Otisao sam na lokalnu postu u Podsusedu ali subotom ne radi. Htio sam doznati koliko je vrijednosna posiljka i kupiti one malo jace tapocirane koverte, nista do ponedjelka.
dadod
Postovi: 871
Re: GainWire mk2
PostPostao/la deleted user » Sub pro 06, 2014 1:25 pm
Mislim da nema potrebe slati kao vrijednosnu posiljku, dovoljno je preporukom u zutu omotnicu s mjehuricima. Omotnica i preporucena postarina po komadu nebi trebala preci 15 kuna..
Re: GainWire mk2
PostPostao/la dadod » Ned pro 07, 2014 12:23 pm
Popis potrebnog materijala:
GainWire mk2 Bill Of Materials
BOM for preamp part:
all resistors metal film 0.25 W 1%
exept marked as 0.1%
all electrolytic caps 25 V PANASONIC FC
all components to have twice as there are two pre amps on the board.
C2 100p ceramic C0G
C3 220p ceramic C0G
C4 100u
C5 22uF
C6 22uF
C7 220p ceramic C0G
C8 220p ceramic C0G
C9 10u (22u)
C10 10u (22u)
C11 100uF
C12 100uF
C13 2.2u polyester or polypropilene
C12 2.2u polyester or polypropilene (DC servo)
P1 10k log 21 steps attenuator up to 50k log
Q1 BC560C
Q2 BC550C
Q3 BC550C
Q4 BC560C
Q5 BC560C
Q6 BC560C
Q7 BC550C
Q8 BC550C
Q9 BC550C
Q10 BC560C
Q11 BC560C
Q12 BC550C
Q13 BC550C
Q14 BC560C
Q15 BC560C
Q16 BC550C
Q17 BC560C
Q18 BC560C
Q19 BC550C
Q20 BC550C
Q21 BC560C
Q22 BC550C
Q23 BD139
Q24 BD140
R3 10R
R4 330R
R5 1k 0.1%
R6 1k 0.1%
R7 330R
R8 10R
R9 390R
R10 33k
R11 470R
R12 470R
R13 3k8
R14 1k 0.1%
R15 3k8
R16 1k 0.1%
R17 6.8R
R17 2k7 (1k5 for 3.5x gain) close to jumper J2
R18 470k
R19 100R (330R for 3.5x gain) close to jumper J1
R20 3k3
R21 3k3
R22 22k
R23 10k
R24 10k
R25 10k
R26 15k
R27 150R
R28 150R
R29 47k
R30 180R up to 270R (biger resistor more output bias current)
R31 180R up to 270R (biger resistor more output bias current)
R32 47R
R34 33R
R36 12k
R38 470k
R39 22R
R40 33R
R41 33R
R42 22R
R43 22R
R44 4.7R
R45 4.7R
R46 6.8R
R47 470k
R50 100k close to jumper J2
R50 1k
U1 LT1022 or similar with jfet input (LF411)
BOM for Shunt Regulator part
all resistors metal film 0.25 W 1 %
some components to have twice as there two independent
shunt regulators, look schematic
C1 100uF
C2 0.1uF polyester
C3 0.1uF polyester
C5 100uF
C7 100uF
C8 100uF
C10 2200uF
C11 2200uF
C12 2200uF
C13 2200uF
D1 1N4148
D2 1N4148
D3 zener 8.2V
D4 zener 8.2V
D5 1N4248
D6 1N4148
D7 1N4148
D8 1N4148
D10 any 1 A diode (soft recovery could be used)
D11 any 1 A diode
D12 any 1 A diode
D13 any 1 A diode
D14 any 1 A diode
D15 any 1 A diode
D16 any 1 A diode
D17 any 1 A diode
J1 2SK170
J2 2N5457
J3 2N5457
M1 DN2540 TO220
M2 IRF9640
M3 DN2540 TO220
M4 IRF640
Q1 BC550C
Q2 BC560C
R1 10R
R2 100R
R3 7k5
R4 10R
R5 220R
R7 470R multiturn trim
R8 10R
R9 100R
R10 100R
R11 100R
R12 7k5
R13 0.1R
R14 220R
R15 10R
R18 0.1R
R20 100R
R21 100R
R24 2R2 0.5 W
R22 7.5k
R23 7.5k
R25 2R2 0.5 W
heathsink SK104.G 4pcs.
dadod
Postovi: 871
Re: GainWire mk2
PostPostao/la dadod » Pon pro 08, 2014 6:45 pm
Pa bas se niste pretgnuli u preuzimanje plocica ili placanju. Do sada su platili samo Schultz i pamook pa cu im sutra poslati plocice. Ne ide mi se bas svaki dan na postu pa vas molim, budite malo azurniji.
dadod
Postovi: 871
Re: GainWire mk2
PostPostao/la dadod » Uto pro 09, 2014 3:21 pm
Danas poslane plocice za Schultza(dvije), SaWu i pamooka !
dadod
Postovi: 871
Re: GainWire mk2
PostPostao/la yoke » Uto pro 09, 2014 4:36 pm
dadod napisao:Pa bas se niste pretgnuli u preuzimanje plocica ili placanju. Do sada su platili samo Schultz i pamook pa cu im sutra poslati plocice. Ne ide mi se bas svaki dan na postu pa vas molim, budite malo azurniji.
ne znam gdje ti zivis ali u hrvatskoj je rok za placanje 30dana..minilano :D
ako dobijes lovu prije tog roka mozes se lupati nogom u guzu :mrgreen:
