Postao/la audio kutak » Pon lip 15, 2020 12:41 pm
Ovo piše u oglasu, citiram ...
"This listing is for a Pair of 3 Chassis 805 Tube Amplifiers Made under Western Electric & ATT Patents. The manufacturer of the amplifiers was Schulmerich. I think they were made sometime in the late 1940 to early in the 1950's and use a pair of 805 transmitting tubes as output tubes. From what I understand the amplifiers are somewhere between 250 to 300 watts of tube power each. Each amplifier consists of one chassis for the power supply and uses 866A rectifiers. One chassis as the amplifier audio output chassis using a pair of 805 tubes. One chassis which is the driver amplifier and uses 6L6 tubes as the drivers along with 6SN7, 6SJ7 and other tubes. The amplifiers come in their original cabinets and were working when they were pulled out of service quite a few years ago. The dims of each cabinet is 45 1/2" high, 21 1/2" wide and 17" deep with a weight of about 200 to 250 pounds each. They were used in big home"
Ako je vjerovati prodavaču, radilo je prije nego se izvadilo iz upotrebe...
Nije mi namjera to kupovati, samo sam htio pokazati što se prodaje...
