PostPostao/la audio kutak » Pon lip 15, 2020 12:38 pm
Evo slike sa druge strane..., Ona prva je bila odostraga...
PostPostao/la audio kutak » Pon lip 15, 2020 12:41 pm
Ovo piše u oglasu, citiram ...
"This listing is for a Pair of 3 Chassis 805 Tube Amplifiers Made under Western Electric & ATT Patents. The manufacturer of the amplifiers was Schulmerich. I think they were made sometime in the late 1940 to early in the 1950's and use a pair of 805 transmitting tubes as output tubes. From what I understand the amplifiers are somewhere between 250 to 300 watts of tube power each. Each amplifier consists of one chassis for the power supply and uses 866A rectifiers. One chassis as the amplifier audio output chassis using a pair of 805 tubes. One chassis which is the driver amplifier and uses 6L6 tubes as the drivers along with 6SN7, 6SJ7 and other tubes. The amplifiers come in their original cabinets and were working when they were pulled out of service quite a few years ago. The dims of each cabinet is 45 1/2" high, 21 1/2" wide and 17" deep with a weight of about 200 to 250 pounds each. They were used in big home"
Ako je vjerovati prodavaču, radilo je prije nego se izvadilo iz upotrebe...
Nije mi namjera to kupovati, samo sam htio pokazati što se prodaje...
PostPostao/la davorin » Pon lip 15, 2020 12:42 pm
Iz slika se mogu vidjeti vrlo veliki transformatori, živine ili halogene VN-ispravljačice, velike ispravljačice u ispravljačkim i filterskim stupnjevima, PIO-kondenzatori i VN-ispravljaču, odvojene šasije VN-ispravljača, izlaznog stupnja i pobudnog dijela, kao i relativno pristojna očuvanost.
Postovi: 7234
PostPostao/la tom_hifi » Pon lip 15, 2020 12:44 pm
Živine ispravljačice.
Dobra je to cijena. Schultz, hoćemo popola? :mrgreen:
Postovi: 5458
PostPostao/la davorin » Pon lip 15, 2020 12:47 pm
Vide se metalne oktalne elektronke pa pretpostavljam da se radi o cijeloj seriji iz američke linije pa su i ispravljačice vjerojatno 866A. Transtormatori (izlazni i VN-mrežni) su kapsulirani i zaliveni u ulju što se radilo samo sa kvalitetnim komponentama, ali ključni podaci bi bili oni sa pločica.
Postovi: 7234
PostPostao/la pamook » Uto lip 16, 2020 9:08 am
https://reverb.com/uk/item/10762453-pai ... -watts-eac
slike ovdje objavljene su identične ovima u oglasu, a na website-u piše da je oglas od prije 2 godine
e sad, ili je navlakuša, ili nešto ne štima, pogotovo po cijeni :P
PostPostao/la pamook » Uto lip 16, 2020 9:28 am
...a evo i oznaka šasija, sa nekog drugog website-a....
PostPostao/la Schultz » Uto lip 16, 2020 9:39 am
tom_hifi napisao:Živine ispravljačice.
Ja bi rado preskočio, ako ikako mogu.... :whistle:
PostPostao/la Master of disaster » Uto lip 16, 2020 11:21 am
Preskakt :doh: u tvojim godinama... Hoćeš da ti koljena stradaju?!
Postovi: 3355
PostPostao/la Edison » Uto lip 16, 2020 11:57 am
Schultz napisao:Ja bi rado preskočio, ako ikako mogu.... :whistle:
Pametno. Problem je smjestiti negdje 200+ kg pojacala, od toga bar 30 kg ruzine... ;)
Postovi: 5894
